Ok I bit the bullet and bought a reman. Z3 rack. I installed it over the weekend and everything went in fine. But when I first bleed the system I had a lot of air in it and and the steering seemed stiff and heavy. After letting it sit over night, I went to start it up and the power steering seemed fine until I went for a drive and it got stiff and heavy again. So Today we brought it into the shop, steering seemed normal, flushed the system again just incase, set the alignment and once again everything seemed fine. I left for work and about 5 minutes into my drive the steering got heavy again like manual steering. When I pulled into my drive I checked the fluid and it looked good checked the belt tightness and it was good. So I started it back up tried to turn the wheel and it was still stiff, until I reved the motor up to around 2000 rpm and it started to get light again.
So I'm hoping one of you that have done this can help me figure out because I am at my ropes end. The problem seems to only happen when fluid gets warm and I can sort of get it to turn easy at park if I rev the motor. If it helps, I used all of the e30 ps lines instead of the e36 pressure line that some use. I have searched all of the boards before doing the swap and know a few that have done it and not have had this problem.
I have a feeling I know what needs to be done next but want some confirmation I haven't missed anything.
Thanks in advance,
Greg
Thanks in advance,
Greg
