p/s fluid fail
  • Rsully70sev
    • 2391
    p/s fluid fail
    I was driving last night at 2am and my car started to make some stressful sounds every time I turned. Last time his happened, it was the fluid. I didn't have any dexwhatever on me, so I had to use the generic gas station STP bullshit. It seemed to work fine, but I've heard this isnt the best stuff to use.
    Should I break out the turkey baster and get it out of there or just let it go? I also read somewhere that you could put tranny fluid in there?!
  • idanity
    • Jun 2006
    • 775
    you said it..
    yes, turkey baste and add ATF ftw.
    if its leaking, you may not have anything left so it may be worth just looking 1st. (at least the pump didn't burn up)
    check the bottom of the reservior, but most common leaks are the racks themselves (time for the 95 m3 swap)
    3 pedal club
    200,k+ club
    cabrio club
    port-matched- polished- purring www.BMWpark.org
    </div>
    linux since 1999
    • 5Toes
      • 9836
      Draining mine out of the reservoir was a REAL bitch.
      I would say drain by undoing the drain bolts on the actual rack.
      • grantlacey11
        • Jan 2009
        • 680
          • 37833
          Standard ATF for the rack fellas, NOT power steering fluid.
          Grover Beach, California
          BimmerHeads.com
          • Danny
            • 14216
            Fuck power steering.
