Spring delete mod summer 2011 the new hype.
Super Slammed
This could totally be a new fad... Spring deletes and sticker-bombed wheels will be all the rage this summer.Comment
4in rear springs and coil-overs up front. that will get you to sit on the floor-FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
-The Beauty in the Tragedy-
MECHANIC SMASH!!- (you all know you do it)
Got Drop?? ;-)
Originally posted by JinormusJBut of course
E30s are know to be notoriously really really really ridiculously good lookingComment
Did you take out your adjuster.
A GC "off the shelf" kit will work for you because they will use shorter koni's and cut the strut housing however much you want.
Even if you cut it about 1 inch and run no adjuster in the back with stock length 5.5 or whatever springs you'll be low. Nice and low.
This is lifted in the back and non cut strut housing. (AKA one inch higher in the front than you'd be, plus if you get camber plates those can lower your ~.5 inch)
Originally posted by z31maniacI just hate everyone.
No need for discretion.Comment
^ haha which eibach's.. pro-kit? you will no be slammed with just some eibach springs. Your mechanic sounds like a tard.Comment
