i want my e30 to be low!
  • ashton
    • Jan 2011
    • 240
    i have the ground control coilover conversion kit on my 88 325i. but it still doesnt make my car as low as i want it. its on bottlecaps with 195/65/r14 tyres :/. can somebody give me some ideas. i want it to be low low. tell me what i should buy or do. i dont wanna cut my springs or anything like that, hopefully i wont have to. thanks.
    ashton.
  • Stephen
    Шлем ишака
    • 10774
    spring height?
    • mrgetbig50
      • 92
      airbags lmso
      • FunfGan
        • Jan 2011
        • 4958
        Good Lord, good idea on not cutting the gc springs. But yea, as Stephen said you may need some lower springs. Also, have you modified the strut tubes?
        Go here be happy!
        Ratchet Garage e30 V8 build.
        • ashton
          • Jan 2011
          • 240
          No i have not, would you please explain how to do that please. im a noob.
          • LJ851
            • 7919
            Get some fatter friends to roll with you. Done.
            Lorin
            The M30 is God's engine.
            • z31maniac
              • 17566
              The strut housing is shortened, then you use a shorter strut insert with a spacer to retain travel whilst going leaux.
              www.gutenparts.com
              • CHIF8008
                • 3447
                cut strut will get you low up front. 4in spring will get you low in the rear
                -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
                -The Beauty in the Tragedy-
                MECHANIC SMASH!!- (you all know you do it)
                Got Drop?? ;-)
                But of course
                E30s are know to be notoriously really really really ridiculously good looking
                • ashton
                  • Jan 2011
                  • 240
                  can you explain how to cut the strut? thanks,
                  • FunfGan
                    • Jan 2011
                    • 4958
                    Well if you're not on shortened shocks the only thing you can modify is the spring perch. Just cut off the old spring perch(leave a little lip), then slide the D-ring that came w/ your conversion kit down to that spot and weld it in place.
                    Go here be happy!
                    • ethrtyiS
                      • 8147
                      wut.
                      '89 BMW 325is | '02 Mitsubishi Montero Limited | '2005 GMC Sierra 2500 Duramax | 2007 BMW M5
                      my feedback thread
                      • CHIF8008
                        • 3447
                        there are plenty of youtube videos and many write ups all over the internet. go to google and type in "how to..." gotta do your part.
                        when cutting the tubes you will need shorter front shocks, because you are making the housing they go in shorter. or else you will blow them(or they might not even fit: depending)
                        also you will need access to a welder and obviously something to cut the tubes apart. plus the necessary tools and know how to pull off and apart your suspension.
                        Got Drop?? ;-)
                        But of course
                        • FunfGan
                          • Jan 2011
                          • 4958
                          I was waiting for somebody to post that.
                          Go here be happy!
