Budget struts with M3 springs?
  • Luciano36
    • Jul 2011
    • 221
    Hey all!
    I just bought a pair of M3 front springs for my 91 vert (only fronts cause I like the height in the rear) and I was wondering if you could recommend a budget pair of front struts. I heard Bilstein touring could be a good option. Can KYG struts be used with M3 springs in a vert? I know Billies Sport are a good option, but I am looking for something less stiff and more comfortable (and cheaper).
    Anything else I should consider replacing besides springs and struts?
    Thanks a lot in advance!
    Aloha!
    Luciano
    Glacier blue metallic 1991 325ic
    • 37832
    Honestly I think KYB shocks are a great and super affordable choice. They will be just fine with M3 springs.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • Stevie30
      • Apr 2007
      • 1534
      The vert on the left has KYB struts with M3 springs front and rear. They ride and handle great.
      1991 325ic and 1991 318is
      • Luciano36
        • Jul 2011
        • 221
        That is great! Thanks guys! What KYB strut model do you have installed? The insert has to be 51mm, right? Do you guys recommend a particular website where I can buy these struts from? Price-wise I mean.
        Thanks again!
        Aloha
        Luciano
          • 37832
          Honestly almost any parts store can get them for you.
          I personally use BMA Parts since they are local and cater to E30 owners. They of course do shipping as well.
          Grover Beach, CA
          www.BimmerHeads.com
          • Luciano36
            • Jul 2011
            • 221
            Thanks a lot! I used BMAparts before and their price and service (shipping to Hawaii) is great. I'll order two KYB GR2 front strut inserts soon. Cheers!
            Luciano
            • aworthybrother
              • May 2007
              • 899
              I had M3 springs and Bilstein touring shocks on my previous vert and I like the comfy ride.
              How much would KYB cost you? Bilstein touring shocks is $269 shipped for all 4 posted in shox.com.
              • klavender1
                • Apr 2011
                • 400
                I got KYB's recently from partsgeek for about $35 each. I'm on stock springs but they are stiffer than I imagined. Which is a good thing. Good for DD though.
                • Philo
                  Ich esse kleine Kinder
                  • 3334
                  KYB's are great on a budget. I usually recommend them for use with M3 springs or H&R sports. (Not Races though)
                  -tim
                  Originally posted by Jordan
                  I like the stance
                  • TrentW
                    • 2815
                    How would Boge Turbo Gas struts/shocks work with M3 springs?
                    Would the drop be like 1" in front?
                    • TrentW
                      • 2815
                      I'm preparing to install M3 springs w/Bilstein Tourings on my wife's '88 325 and read somewhere that it will drop approx 3/4". Is this all around or only in the front? Car currently has OE springs w/red stripe and realoem lists a 9mm upper spring pad for the red springs or also a 3mm pad. Which did you guys use?
                      • aworthybrother
                        • May 2007
                        • 899
                        I had an m42 vert, so engine was lighter and front had more fender clearance. I had to use thicker spring pads in the rear and 15mm drop hats in the front. I also removed the front spring pads and replaced it with a bicycle tire tube.
                        Oekundar had a 325 vert with m3 springs and drop was great. Try to search his thread.
