Rear Coilover Spring Help!
  • bigredguy
    • 357
    I ordered a set of JOM coilovers for my car, and i know that the rear will need to go lower. First thing, are JOM adjusters made to fit a 2.25 ID spring like most others?
    Are there any companies besides Hyperco that make 4 inch spring?
    What would be a good spring rate for a DD? I was thinking 600, but it sounds a little soft.
    Also if anyone has any 4 inch 2.25 ID springs for sale i would definately be interested in buying them.
    Thanks
    INSTAGRAM @ merlow_
  • bmwguy325is
    • May 2011
    • 1263
    I am guessing you are leaving the spring in the stock location?
    600 should be fine. I run 750s for a race setup. As for who makes em Just buy hyperco.
    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
    • bigredguy
      • 357
      i dont know what you mean by stock location. I know the rear springs of the JOM coilovers dont go low, so i am getting a 4 inch spring so i can still run the adjuster and go lower. Does anyone know if the JOM adjusters work with a 2.25 ID spring?
      INSTAGRAM @ merlow_
      • E30_fiend
        • Apr 2006
        • 7348
        they should work with the 2.25" spring.
        Also, 600 is by no means soft. Most guys that buy coils are running like 350-500 front and 450-550 rear. 600 should do just fine for DD. I DD my 600fr 750rr setup. I love how stiff it is.
        Taylor
        • bigredguy
          • 357
          ok thanks alot. anyone know what would be the cheapest 4 inch spring? anything cheaper than $65 each?
          INSTAGRAM @ merlow_
          • bigredguy
            • 357
            also would i be able to go with a 4 inch spring with the JOM shocks?
            INSTAGRAM @ merlow_
              • 37833
              You could also run the JOM spring without the adjuster.
              Otherwise, check Summit Racing for springs.
              Grover Beach, California
              BimmerHeads.com
              • bigredguy
                • 357
                ok thanks. if i got a 4 inch spring, would the JOM shocks not be able to handle it, and blow quickly?
                INSTAGRAM @ merlow_
                • E30_fiend
                  • Apr 2006
                  • 7348
                  that spring would lower the car quite a bit which could blow the shocks. You would be hard pressed to find a non adjustable dampener that wouldnt blow at that height. If you are going to go that low, you should get a shock that will handle the smaller spring better.
                  Taylor
                  • NPCe30
                    • Jun 2010
                    • 55
                    what did u end up doing?
                    • bigredguy
                      • 357
                      nothing yet. insurance is a bitch to pay with such shitty jobs and school. im going to be ordering the 4 inch springs most likely, and maybe shocks down the road when i get the money.
                      INSTAGRAM @ merlow_
