Polyurethane Bushings with sway bars
  • aTron12
    • Nov 2009
    • 98
    Hey guys,
    I'm installing a vert bar in the front and also redoing my entire rear end, including bushings and IE weld on camber kit. Since it will all be out I am looking into new bushings for my rear sway bar. I'm also running H&R sport springs.
    If I go with the Poly:
    1. Will it actually make a difference in performance?
    2. Will they squeak
    3. Will it ruin my ride quality
    I don't track it. Just have fun around corners and driving through the mountains.
    Thanks,
    Adam
    If you don't track the car, stick with OE bushings.
    • Hellabad
      • 807
      I agree. There is a reason that not a single new car you can buy, has urethane bushings anywhere.*
      Jay
      *disclaimer for bimerforums participants:
      I am aware of the one year only experiment by Chrysler in 1995 on the Cirrus, but they have all been replaced. And I consider the 1988 IROC to be actually more like nylon than urethane.
      Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
      Ground Control Gallery
      The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
      • bmwguy325is
        • May 2011
        • 1263
        Originally posted by aTron12
        Hey guys,
        2. Will they squeak
        1. They last longer than OEM
        2.If you grease them when you install the bar no. Only the poly trailing arm bushings get squeaky. But grease can sure that too.
        3. No
        sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
        The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
        • SkiFree
          • Jun 2011
          • 2766
          It's really about how you want the car to feel, not really a question we can answer
          without mind reading.
          I'd personally go with urethane on those particular bushings but i have my own reasons which may not be similar to yours.
          ADAMS Autosport
          • aTron12
            • Nov 2009
            • 98
            I ended up going with OEM. Found a Vert sway bar and ordered my bushings/links on Pelican. The current bushings including the links are so incredibly crapped up that I think this will make a great difference. Thought I would take the safe route-- I'm sure this will be a nice improvement. Thanks for the input, gents.
            • AE86
              • 272
              Post pics! I'm interested in doing this too.
              WTB: Diamond Schwartz Hood
