Hi all,
I recently put the car up on the lift and took a look underneath to see what maintenance I needed to do. I saw that the control arms had rusted and the bushings are in bad shape. I've also noticed that there is a clunking sound that comes from the front suspension, and I'm not certain if this could be resulting from the condition of the bushings.
So I have a couple of questions:
Thanks!
- Should I need to replace the control arms too, or can I just replace the bushings?
- I found the "Powerflex Control Arm Bushing with Offset Hole - Urethane" on bavauto, and I was wondering if anyone has experience with these. Are they substantially better than the factory OEM?
- Being new to suspension work, I'm not sure what impact the offset holes have on the setup.
Thanks!
