Cutting Springs.....
  • ak-
    • 12422
    Originally posted by PNWDan
    Bounce is caused by cutting the springs. Cutting a coil off the spring increases the spring rate and thus the spring rate becomes to strong for the factory shock to control. This is why your shocks and springs should be matched.
    M3 springs are the same as the standard E30 springs minus one full coil. I have experimented and cut up to 2 coils off the factory springs before the rate overtook the factory shocks. I currently am running with 3 coils cut and billie sports. No bounce
    lol stock springs are rated 105lbs, cutting them a few coils is not going to significantly increase the spring rate and get them to be bouncy.
    Many people here run h&r sports, which are stiffer than stock obviously, with stock replacement kyb shocks and the ride is perfect.
    He is going to bounce due to hitting his internal bump stops if he cuts too much not because of rebound specs/matching
    1991 325iS turbo
    • PNWDan
      • Feb 2011
      • 1326
      I disagree.. but either way cutting them wont be as detrimental as people try and tell you. Just don't add a lot of heat into them when doing it or you'll get an uneven rate
      1987 Alpinweiß 325is
      Like the PNW E30 Local Crew Facebook page
      • ak-
        • 12422
        See now heat is a different story, that can detrimentally change rate since it's unevenly applied to the coils
        1991 325iS turbo
        • acolella76
          • 2950
          I actually don't even use springs anymore. Or shocks. I welded in a solid piece of steel pipe so the bitches know i'm totl srs.
          -Alex
          • OnMy2ndE30
            • Sep 2011
            • 385
            Only heat made would be from the sawzall cutting through the coil.....no hot wrench here unfortunately.....
            I did find a set of e36 m3 springs.... I have used them before, but with stock shocks. gives a nice lowering rate. I think I may have the Billy sports in the front of my car. I have them in the rear and would assume they are the same in the front.
            • ROLLingKING
              • Apr 2011
              • 1169
              I was gonna hate and comment DONT CUT SPRINGS. leave it for hondas.
              but then I thought about it and re-read the original post. id say cut away at your stock springs.lol if your shocks are old and worn expect slight problems after cutting.lol but hey xmas and weddings are more important things.
              good luck. cut and post pics. only u will know when ppl say, hey nice stance.haha
              m20 is plenty. im simply a drifter.
              build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
