Camaro Shocks
  • Rodneye30
    • Sep 2020
    • 5
    #316
    Anyone that can assist with a write up on how to do the spacers for the AGX's (MR2 fronts / Camaro rears combo?
    • Rodneye30
      • Sep 2020
      • 5
      #317
      Wouldn’t mind paying to get them done
      • eLKuRLy
        • Oct 2007
        • 360
        #318
        I believe the spacers are just metal tubing. Just cut it to size you need. It might differ if you are cutting down your struts. On post #14, there is a picture of the tube size he used on stock/unmodified struts I believe.
        • cdl723
          • Jan 2015
          • 144
          #319
          For those of you using 2.5" springs with GC coilovers, what top hat/spring perch did you use?
          Edit: I used a generic Honda Accord coil over kit’s top hats. They were $46 and I drilled them out to 15mm to fit. Only issue now is the stack up with IE camber plates is a little too tall....
