No. I used the rears. They are only 2" shorter compared to 4" like the fronts.
Camaro Shocks
www.gecoils.com
My euro 316 project Transaction Feedback -
You don't need to. You could cut a length of pipe and place it inside the strut tubes to take up the space. Maybe take the old inserts, cut off the bottom two inches in a chop saw, fill it up with sand and weld a disc to the top to seal it. Perfect fitting incompressible spacer that's cheap and lighter then a solid metal spacer. Just spit balling for those who don't want to go low. When you chop it even the highest setting will be around h&r races.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
My euro 316 project Transaction FeedbackComment
Looks like it is square like Koni style. Although there was mention of the threaded shaft end being bigger diameter of the strut bearing for e30's.
You will have to press out the bearing and find a suitable replacement that will accommodate the bigger shaft for stock strut mounts.
May be other options on camber plates depending on the brand used.Comment
The struts have a 15mm diameter so the standard bearings and such will not fit since they are 14mm. I'm going to toss my camber plate sleeve inserts on the lathe and bore them out.
Also just ordered part # 6659k15 from mcmaster.com for the rears.
I was also wondering if the mustang units would be a better choice. They are supposed to be shorter from what i've read and they already have a sleeved inserts
Not sure which year. Can one of you guys who works at a parts store confirm?
http://www.amazon.com/KYB-743020-Man...4770690&sr=8-1
or
http://www.amazon.com/KYB-Adjust-Rig...4770758&sr=1-2Last edited by einstein57; 12-24-2011, 04:09 PM.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
I was thinking of probably doing this - using shorter bilstein IX for the fronts and the camaros for the rear. I already have GC camber plates and I didnt want to run into any issues with the kyb fronts to my plates.Comment
