I’m replacing the control arms, CAB’s (E30 M3), and tie rods on my wife’s 1988 325 (aka “Black Betty”) and while I’m in there I’m thinking of upgrading the struts, but have some questions.
I’m going to keep the car relatively stock and retain the original springs, as it needs to retain close to stock ride height and comfort. She doesn’t want the harsh ride of my car with H&R Sports/Bilstein Sports. While I would ideally prefer to get rid of some of that front fender gap, (may add some E90 drop hats just for good measure) remember, this is my wife’s car and since I’ll be adding an “is’ front lip soon, I don’t want her tearing it off on a parking barrier the first time she pulls into a parking space. I measured the clearance with the stock lip and there’s a good 8 ½”, but the “is” lip is 1 ½” thicker at the widest point, so I’ll already be down to 7” of clearance, and just over 6 ½” if I add the drop hats, which may actually be too low. Maybe I can get her to promise to back into any space with a curb. ;)
I’m considering replacing the front struts with slightly sportier ones, and was thinking of going with Bilstein HD’s, but found out the damping is the same as the Sports, which will be too harsh. I’m considering Koni adjustables—any advice on this? Checking realoem.com for part #’s so I can also order new upper strut mounts, I noticed there are two different upper spring pads (item 10), a 3mm, or a 9mm that is to be used with “red springs”. The springs currently on the car have a red stripe on them—see photo. What are these red springs? Since a taller spring pad would compress the spring more, are these some type of OEM sport spring pad or something? I’m curious because the rear shocks are yellow Sachs E30 M-Techniks, with #’s 81 4901 556 757 (see photo) and am wondering if someone upgraded the suspension at some point. I searched for a way to identify different stock springs but found nothing but a listing of spring rates.
Any knowledgeable advice on the Konis and/or the “red springs” is appreciated.
http://www.realoem.com/bmw/showparts...11&hg=31&fg=10
http://www.flickr.com/photos/59243816@N07/6332977364
http://www.flickr.com/photos/59243816@N07/6332226165
http://www.flickr.com/photos/59243816@N07/6332977060
