Squeaking/Creaking noise from rear
  • zig553
    • Sep 2011
    • 189
    Everytime I go over bumps (big or little) at any speed I'm hearing this creaking sound coming from the rear. Any ideas what it may be?
  • KenC
    King of Kegstands
    • 14396
    Do you have poly trailing arm bushings?
    Originally posted by Gruelius
    • zig553
      • Sep 2011
      • 189
      I'm not sure, as far as I know everything is stock. Is there any way to tell what poly arm bushings look like and where they are located?
      • KenC
        King of Kegstands
        • 14396
        I'm guessing the creaking is the trailing arm bushings, especially if the noise is over bumps.
        • lbreevesii
          • Aug 2009
          • 412
          That or upper strut mounts. That seems to be the cause of mine at the moment.
          I don't always wreck cars, but when I do I wreck them into trees.
          91' 318is S50 swap - The Black Widow
          • KenC
            King of Kegstands
            • 14396
            Bad rear shock mounts usually result in a clunking
            • e30slidewayz
              • 813
              I'd guess that the trailing arm bushings are probably the cause
              • zig553
                • Sep 2011
                • 189
                Any idea how hard it is to replace them? Can I live without replacing them? If the job is too difficult any idea how much it would cost at a shop to replace them?
                • lbreevesii
                  • Aug 2009
                  • 412
                  yup, but one of mine is actually squeeking at the moment. Granted though, I think a trailing arm bushing may be squeaking too. gah.
                  • E30 331is
                    • Sep 2011
                    • 1166
                    If its a coupe and your back windows are the opening type, youd be surprised it can be from that.
                    • E30_fiend
                      • Apr 2006
                      • 7348
                      99% sure its your rear shock mounts. They will squeak before they start clunking. Mine have always squeaked. Thats when I know its time to change them.
                      Taylor
                      • PannikAttk
                        • 120
                        Taylor
                        This is likely the culprit. If you're on stock suspension, I'd switch to the JT rear mounts that Turner carries http://www.turnermotorsport.com/p-36...unts-pair.aspx
                        It's a nice upgrade over stock and should do the trick. The bushings are also replaceable and cost around $15 for future maintenance. I'm running these on my GAZ coilover setup and although I should be running a stiffer, spherical mount, these are holding up just fine.
                        You can always go a little cheaper and pick up these lifetime mounts, but I can't say I know anything about these. http://www.turnermotorsport.com/p-34...unts-pair.aspx
                        I might be switching to the spherical mounts in the coming days, so if you wanna buy JT ones that I've been using for about a year, I'd provide a hefty discount over the $99 price :)
                        Daily driver, never tracked or abused. Prob 3k miles on the mounts.
                        1990 BMW 325is 5spd - Brilliantrot
                        M52 - Scorpion exhaust - GAZ Coilovers
                        • Mr. Tasty
                          • Jul 2011
                          • 3421
                          like everyone else is saying, must be RSM's
                          2014 Alpine White 335i MSport
                          (Daily Driver)
                          Full Mperformance Aero
                          KW V2 Coilovers
                          VRSF Catless Downpipes
