Dropped on races too low in rear
  • bastianshaw
    • Jan 2007
    • 2210
    What are my options? I was thinking of running these in addition to the stock pads :http://www.turnermotorsport.com/p-42...pads-pair.aspx
    I dont want to drop the front anymore so no drophats or cutting front springs just need to raise the rear
  • nrubenstein
    • 3148
    Those pads work great.
    Edit: You can use them top and bottom if you need an extra lift.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • Blackout
      • Apr 2011
      • 4130
      you can also sell your E30 H&R Race rear springs and get E36 H&R Race rear springs from someone on bimmerforums. So many E36 dudes selling their races and switching to coilovers.
      I tried E36 H&R Races in the rear on an E30, handling was awesome. Drop was maybe 1 inch.
      You will make money if going this route. There are members looking for E30 rears here.
      Or you can just get those thick pads from turner...
      » PARTS FOR SALE
      » TRANSACTION FEEDBACK
      • kinvodA
        • Sep 2009
        • 278
        Just to clarify: these will work on an e30? Their site doesn't mention God's chariot. However, since people use e35 springs I imagine you are right and the spring pads will work just fine.
        "Wow. We're just blowing through nap time, aren't we?"
        • Blackout
          • Apr 2011
          • 4130
          Yes, they work on E30.
          » PARTS FOR SALE
          • bastianshaw
            • Jan 2007
            • 2210
            Any other ideas?
            • LJ851
              • 7919
              Here is an amazing solution , haha!
              The fronts settled just a little so i took out 1 pair of my spacers. I now have 4 spacers i don't need (i made 8 and am using 4) if you want them,i dont want a lot of money for them.
              Lorin
              The M30 is God's engine.
              • bastianshaw
                • Jan 2007
                • 2210
                LJ851 You got PM!
                just FYI guys the Races AND the IE3s drop the rear too much IMO, the spring rates are killer though :-)
                • einstein57
                  • Jun 2007
                  • 10780
                  You must have really tall speed bumps or something. I was running a 3" exhaust with no spring pads and they still felt too tall. Did not start scrapping the exhaust till i installed e90 drop hats.
                  Before With H&R races
                  After with coils 8)
                  www.gecoils.com
                  • bastianshaw
                    • Jan 2007
                    • 2210
                    heres mine it looks way lower than the one
                    • einstein57
                      • Jun 2007
                      • 10780
                      Probably cause mine is an early model with higher arches. Did you remove your trunk tar? That would probably even it out.
                      www.gecoils.com
                      • bastianshaw
                        • Jan 2007
                        • 2210
                        Trunk tar removed and that pic was w the tank almost emPty :-/
                        • lbreevesii
                          • Aug 2009
                          • 412
                          dropped my 318is on races. Tad too high in the front(not too low in the rear :-p)
                          I plan to correct with camber plates(ie's sit a little lower), an S50, and possibly drop hats :-D
                          I don't always wreck cars, but when I do I wreck them into trees.
                          91' 318is S50 swap - The Black Widow
                          • gp.plus
                            • 416
                            Heres the bimmerworld 15mm, just came today :)
                            • bastianshaw
                              • Jan 2007
                              • 2210
                              now after spacers
