318is on 318i
  • mbulsa
    • Oct 2009
    • 313
    318is on 318i
    Hey, just getting ready to get a winter set up together, what are the differences in the IS struts, they'll fit fine into my 318 right?
  • Uber E30
    • 1409
    Besides cosmetics there is little difference between a 318i and 318is, the only notable thing is the LSD. So yes, struts are the same.
    -Alex
    • xxlbimmer
      • Dec 2010
      • 156
      If its an E30 318i it probably has 45mm struts, and your 318is probably has 51mm. If you are changing over the whole shabang, no biggie. If you are swapping strut cartridges, I don't believe it will work!
      Chris Leone
      chrisleonemotorsports.com
      rollcages and fabrication
      Remember cross threading is the only thing stronger than loctite!!
        • 37833
        If it's an EARLY 318i it will have the small struts.
        Late model 318i uses the same stuff as the 318iS.
        Grover Beach, California
        BimmerHeads.com
