My initial test drive of my now Z3 rack swapped car was great except I have some bump steer and the rack doesn't return to center.
I searched and found a few threads that sound like a similar issue, none of which show any resolution to the problem.
1) http://www.e30tech.com/forum/showthread.php?t=109119
2) http://forums.eurocca.net/showthread...ering-problems
3) http://www.r3vlimited.com/board/show...turn+center%22
4) http://e30tech.com/forum/showthread.php?t=83378
5) http://forums.eurocca.net/showthread...ack-Conversion
6) http://forums.bimmerforums.com/forum....php?t=1200770
Background info:
1998 2.8 Z3 rack w/ 120k miles
1991 325i airbag equipped car
new E30 tie rods
e30tech alum. rack spacers installed above the rack
power steering working, filled with Lucas ATF fluid
alignment set to slight toe-in visually
had to get a used steering u-joint because the splines were bad on my original one
Problem:
I got my steering rack installed (not as easy of a task as I would have thought, but im sure if I ever do it again it will be a breeze). I topped off the res. and gave the car a few cycles back and forth with the steering while the engine was running (car off the ground). One observation is that after the first couple steering cycles the steering resistance increased. It still feels like a reasonable amount of resistance, but I thought it would behave the exact opposite and operate with increased resistance until the air bled out, then suddenly have less resistance once all the air was out. I got the car back on the ground and could feel the power assist working nicely. While driving the car it does not want to return to center. If I am making a right turn from a stop, as soon as i begin accelerating the car will just want to turn tighter to the right, rather than straighten out. Hitting bumps causes the steering wheel to turn one way or the other.
Initial thoughts:
I don't believe it to be an alignment problem: I went back home and noticed the toe was out just a bit, I turned it to toe in a tad and could feel that the alignment was set to toe-in on the next test drive, but the problem persists and do not believe a proper alignment ( will get one in the spring, car will be parked for the winter) will resolve the bump steer/ return to center issue.
I don't believe it to be related to the suspension or steering geometry:The suspension was completely refreshed a year ago and the car has driven absolutely perfect, stable, no noises, great steering return before the swap. Someone else with a Z3 rack and the same suspension setup does not have any issues, many other people have swapped the rack successfully using the same spacers in the same position, same tie rods etc.
I feel the steering joint (old flex disk) might contribute to the vague on-center feel, but not the root cause of my problems : link 6 up above mentions a little about this. I got a used steering joint because I ruined the splines on my original one. This used joint looked to be in comparable shape to the original and the u-joint is free of slop. The steering joint is not on any funky angles and I do not notice any binding in the joint or flex disk while turning the wheels back and forth. I would still like to get a fresh flex disk in there to be sure.
Something hydraulic related? I am thinking this is most likely it I am certainly getting power assist. Everything feels nice and smooth and I can turn the wheels with minimal effort with one hand while at a stop. I am not too familiar with the voodoo that goes on inside the steering rack, the valving and such. It is as if the rack is receiving pressure to both sides of the rack simultaneously. To me it seems that if I was running manual steering and had problems returning to center, that it would be an alignment issue, but this feels like the rack is receiving hydraulic assist and every little bump in the road is amplified by the assist. It sucks to think about buying a bad rack and installing it :( but its a junkyard rack so its entirely possible. I am hoping that since the rack has not been used for at least 6 months (had plastic plugs in the pressure hose fittings to keep dirt and moisture out) that anything hydro related will sort itself out with the exposure to the fluid and that with a little time, that things will be working normal inside if they arent currently doing so.
Rack preload/lash adjustment? Maybe a little bit I suspect that loosening the lash adjustment on the bottom of the rack would be my first step. It seems that if its too tight that it would not return to center, but that does not explain the bump-steer behavior.
Sorry for the long-winded post. I am hoping that someone has had this issue and knows the solution and that hopefully this thread can be helpful for someone down the road with a similar issue (once resolved).
Background info:
new E30 tie rods
Problem:
Initial thoughts:
