IE Camber Plates
  • Robert
    • Dec 2010
    • 3770
    IE Camber Plates
    Just recently installed some camber plates with some IE3 springs, the springs are seated correctly so i think , i checked each side 3 times , and i hear clunking when i do turns. I got the IE Street/Track camber plates. Any Ideas? Is this normal ?
  • monster89
    • Sep 2011
    • 234
    Do you think there too big you should try to tell some one if they turn the wheel while you check under the car
    • Robert
      • Dec 2010
      • 3770
      Well i didnt' even max them out and the top hat hits the inside of the shock tower ,
      Not even close to maxed out,
        • 37832
        Shoulda got the GC Touring. ;)
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • SkiFree
          • Jun 2011
          • 2766
          Robert, did you try calling IE, they have the diagram showing the proper orientation.
          Biggest issue I see happen is when the installer leaves out the Compliance spacer (goes below the bearing on the strut shaft) which does not allow for full articulation of the plate in relation to the rest of the strut setup. In short in will bind in the corners because as the strut turns it binds against the stationary plate (seeing as its bolted to the strut tower).
          Good way to check for enough clearance is when you have the strut assembly on the work bench (with the spring off) you should be able to put your hand on the camber plate and swivel it around.
          ADAMS Autosport
          • White325is
            • Oct 2006
            • 5947
            This.
            Ive found out before that IE doesnt make good camber plates.
            • SkiFree
              • Jun 2011
              • 2766
              Originally posted by White325is
              This.
              The camber plates work fine.
              Think the point of this thread is to help find out what his issue might be, not trash talk.
              ADAMS Autosport
              • White325is
                • Oct 2006
                • 5947
                Ive actually made them thicker, end plates longer, So there for stronger and better.
                No different than them (you) making a front strut bar copy of sparco. Well other than not improving anything on the design.
                Ive used IE plates on two different cars in the past and had problems with them. So just speaking from experience.
                Lets stay on topic here. This thread is about camber plates, not strut bars.
                • SkiFree
                  • Jun 2011
                  • 2766
                  ^ Hence my ninja edit, no point in arguing that here.
                  ADAMS Autosport
