My 91 318is is not sitting level in the back. It is an inch lower on the driver side than the passenger side with the stock stuff in there. I put some E30 M3 springs in and replaced the shocks and it is still 1 inch low. When I installed the springs I removed the isolators so that is not the cause. I know the new springs sit right on another vehicle so they are not bad. What could this be? Im thinking it is rooted in one of these issues.
Bent subframe?
Bent arms?
bad trailing arm bushings? (but the tires are wearing normally so if they are bad it is not too far out)
Bent spring perch on the body?
This is really driving me crazy!!!!
I'm thinking of replacing the whole subframe with a junkyard one that I put all new parts on but I don't want to just use the parts shotgun on this.
Bent subframe?
Bent arms?
