New Springs
  • Mr. Tasty
    • Jul 2011
    • 3421
    New Springs
    Well I recently dropped my car with KW 60/40 springs. Put the car on the ground. Rolled it back and forth. Then took it for a slow drive. I noticed it makes a loud spring binding noise when I turn? Will this go away eventually? I also looked and it looks like the bottom spring sits on the spring below it.
    2014 Alpine White 335i MSport
    (Daily Driver)
    Full Mperformance Aero
    KW V2 Coilovers
    VRSF Catless Downpipes
  • AE86
    • 272
    Make sure #5 in diagram is tighten all the way!
    WTB: Diamond Schwartz Hood
    • ak-
      • 12422
      ^^ What? Nooo. That nut isn't suppose to be super tight. Just snug tight.
      #7 and #8 spacers are important, you installed them right?
      And make sure the spring is fitted to the top hat correctly (#9). Top and bottom.
      1991 325iS turbo
      • Mr. Tasty
        • Jul 2011
        • 3421
        yes, the washers are on. I made sure when the car was put down that the springs were in the little sections. It seems to make more noise on the pass side. I will check that out
        (Daily Driver)
        KW V2 Coilovers
        • AE86
          • 272
          "snug" tight or what ever adjective you choose, just make sure its tight.
          • Mr. Tasty
            • Jul 2011
            • 3421
            I think I over tightened my nut. It wasn't allowing the spring hat to rotate.
            (Daily Driver)
            KW V2 Coilovers
              • 37834
              You can't overtighten the top nut, I always put them on with a 1/2" impact. If the strut mount isn't rotating then you are either missing a washer somewhere or have it in the wrong place.
              Grover Beach, California
              BimmerHeads.com
