Steering NOT Returning
  • mcruz121
    • 288
    Steering is not returning to center after a turn stays at 11/1 o' clock until I correct it. Can anyone give me some possibilities?
    Background info:
    Upgraded to Bilstein sports and H&R Race had it aligned at NTB
  • luTTz
    • May 2007
    • 204
    caster. toe.
    • mcruz121
      • 288
      what is the suggested setup
      • EyExR
        • Jan 2011
        • 959
        toe it in a little and use M3 offset CABs...
        I'm having the same issue now, after a complete suspension refresh (front and rear) and 3 alignment jobs. My next step is the offset CABs... I had originally stayed stock everything...
        My 325iX DIY Threads:
        Front Wheel Bearing Replacement
        325iX Rear Subframe Bushings and MUCH more w/pics!
        325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
        • mcruz121
          • 288
          Let me know how the new CABs work for you
          • e30leigh
            • Mar 2012
            • 481
            ive run the m3 cab's in heaps of cars. and with the alighnment setting the toe right they centre faster then normal due to the extra caster.
            if the alighnment is right then i would suggest the rack is bent. or bearings are stiff.
