just installed a 95' m3 rack and all seemed to be well until I added fluid. right when the powering steering began to function the car steered immediately to the left and will do that until its at full lock. Does it sitting still
steering rack help
always get an alignment after any kind of suspension work. -
I am assuming that you mean the wheels are turning with no input from you at the steering wheel (with the car on stands) and not that it is just pulling to one side as you are driving.
Did you get the air out of the system or just refill the reservoir and call it a day? You need to turn the steering wheel lock to lock several times to work the fluid through the system.sigpic
'86.5 325eis Track Ho | '08 128i DD | '04 Silverado Tow VehicleComment
Yeah it automatically steers to the left violently just sitting there, driving it is terrifying. I tried a bunch of times to work the wheel back and forth and kept checking fluid level to make sure the system bleed. unfortunetly this is a cheaper re-man rack so it could be bad :(Comment
