Solved
  • Nick's e30
    • Mar 2012
    • 676
    Solved
    As title states. What is the difference in length between these 2 shock inserts? (the longer part)
    Thanks all.
    No antenna? I sell plugs!
    Here: https://www.r3vlimited.com/board/sho...77#post4937877
  • mr.vang
    • 4371
    ix insert are shorter
    • ak-
      • 12422
      3"
      1991 325iS turbo
      • e30leigh
        • Mar 2012
        • 481
        sssooooo, they would suit lowerd cars is you sat a well made 3" spacer under the shock?
        • e46s54dr
          • May 2008
          • 1059
          Seems to me that throwing in an ix strut with a 3 inch spacer will pretty much be the same as a regular strut in terms of travel.
          The length of the housing is actually what limits the stroke so Id be more effective if you were to shorten your strut housings an inch or two and throw in the corresponding spacer. That will increase your stroke.
            • 37832
            What's the point then? The regular E30 Bilstein Sports are cheaper.
            People use the iX inserts with modified (shortened) strut housings.
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
            • mr.vang
              • 4371
              Originally posted by Nick's e30
              Can anyone else confirm that it is exactly 3''? If so, I'll machine a spacer at work today.
              Nick
              it doesn't work that way for ix insert. you will have to shorten the strut housing. if you want spacer for the insert, make it 2.5 since the insert nut will need space to screw it in.
              • einstein57
                • Jun 2007
                • 10780
                You will have ZERO benefit if you don't section your strut tube. Don't waste your time or money if you don't have plans in hacking at least an 1" out of your tubes.
                www.gecoils.com
                • e46s54dr
                  • May 2008
                  • 1059
                  Youre not quite understanding the concept. If you put the spacer on top of the shock and below the locking nut that'd be even less shock stroke. Think of it as a 3 inch steel bump stop.
                  A lowered car will usually have 5-6 inches of compression and rebound from its ride height max. In our e30s case, its more like 3-4 inches. Now if you put the spacer on top, you will shorten the piston length that is exposed through the housing. That fact paired with the already shortened ix insert will leave you with pretty much no travel. I doubt you'll even be able to get a spring in between the spring perch and top hat.
                  • e46s54dr
                    • May 2008
                    • 1059
                    Simply, you want the most downward travel you can get, not the least.
                      • 37832
                      It kind of makes sense now...I think I'm going to just find the correct shocks.
                      Didn't I already suggest that?
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • ohthejosh
                        • 4963
                        funny thread but good info still came out of this thread.
                        SO MUCH MORE TO DO!!
                        IG: ohthejosh
                        LEGIT CHECK ME BRUH
                        BUYER FEEDBACK THREAD
                        • E30_fiend
                          • Apr 2006
                          • 7348
                          This is the difference between a stock length bilstein sport on the left and a iX bilstein HD on the right.
                          I dont have a picture of this because I was alone but when I fully compressed the stock length shock, It was about a 1/2" shorter than the fully extended iX bilstein. That just goes to show you are gaining HUGE amounts of travel with a shortened housing and an iX insert. You will drive your frame into the ground and STILL have strut travel.
                          • LJ851
                            • 7919
                            Originally posted by E30_fiend
                            That just goes to show you are gaining HUGE amounts of travel with a shortened housing and an iX insert. You will drive your oil pan into the ground and STILL have strut travel.
                            Fixed.
                            Oh, and thanks for that pic.
                            Lorin
                            The M30 is God's engine.
                            • E30_fiend
                              • Apr 2006
                              • 7348
                              Lolol
