adjustable camber kits F/R needed
  • bimmernut333
    • Feb 2012
    • 97
    Ok tomorrow I'm putting in my bav auto springs and billy's. However I have learned from past cars that it'll chew the shit outa my tires without an adjustable camber kit. SO I'm curious if anyone knows where I can get decent ones cheaply? Any info would be GREAT!
    THANKS
  • 801coppertop
    • 293
    Oh boy, I guess I have to be the one to say it.. Search. You will need camber plates for the front, and either adjustable rtabs (reputation says they don't hold alignment) or weld in camber adjusters. The latter you can find on e30tech.com home page. Camber plates will take a little more research on your part as there are so many options.
    • AE86
      • 272
      ^ Ditto what he said.
      Camber plates, and weld on adjusters "help" you get back to original suspension specs. Also you may want to look up "Revshift" , I believe they make a bushing kit that give you a little more positive camber too. Goodluck.
      WTB: Diamond Schwartz Hood
      • bimmernut333
        • Feb 2012
        • 97
        I've used the bav auto rear camber kit in the past with good results, so i'll prob go that route again for those. But as for the front plates there are so many options like you mentioned. What have others here used? And do you know who sells a DECENT front kit? Because I'm kinda on a tight budget right now. I'll definitly look into the suggestions you've already mentioned though.
        • ROLLingKING
          • Apr 2011
          • 1169
          kmac- 329ish
          ground control- 329
          Ireland Engineering- 270ish
          check out IE's website. u need to order the right diameter camber plates for your springs
          m20 is plenty. im simply a drifter.
          build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
          • 801coppertop
            • 293
            The bav auto kit is ~270, eccentric bolts with weld in adjusters are 150 plus labor. And they shouldn't wear out. Just my .02. As far as front camber there are some on sale in the for sale section...
            • Mr. Tasty
              • Jul 2011
              • 3421
              THANKS
              toe is the destroyer of tires, not camber.
              2014 Alpine White 335i MSport
              (Daily Driver)
              Full Mperformance Aero
              KW V2 Coilovers
              VRSF Catless Downpipes
