Want to run a Z3 rack on 318is...
  • dannyg
    • Mar 2007
    • 1553
    Looking to run the zionsville conversion kit on my 318is:
    Do I need to swap over to a non airbag steering column?
    Thanks,
    Danny
    1993 325ic Schwarz/Natur
    1991 318is Black/Black - Slicktop - Project s52
    1989 Alpine White/Black M3 S52
    1988 Henna/Pearl M3 <3
  • FredK
    • 14763
    No. You will have to slot the firewall around 3/4", but you can use the stock airbag steering column and steering linkage.
    • dannyg
      • Mar 2007
      • 1553
      Thats what I was thinking...I don't know why this guy is telling me I need to swap the column.
      • F34R
        sLaughter
        • 12376
        You don't lol, and don't waste the money on that.
        http://car-part.com/
        Search for a steering rack from a 1996 Z3 from your area code. I got mine shipped to me for 160.83 74k miles on it.
        Remember that the 1.9 Z3 came with the lower ratio. So look for that and make sure you ask them before buying. I almost bought one from a 2.5 because they listed it wrong.
        Good luck and you only need some metal washers and 3/8 3" bolts.
        Instagram: @BWeissLeather
        Current cars:
        ~ '87 325 M30B35 swap
        ~ '87 535
        ~ 01 540 Msport 6spd
        ~ '06 X5 4.8is
        • dannyg
          • Mar 2007
          • 1553
          Just found this:
          http://www.rmeuropean.com/bmw-e30-steering.aspx
          Don't need to modify my knuckle either?
          • F34R
            sLaughter
            • 12376
            Just found this:
            I used a IE poly disk and my 1/4 die grinder with a carbide bit to remove the binding metal for more movement.
            Current cars:
            ~ '87 535
            ~ '06 X5 4.8is
