How to put E30 M3 sway bar links on an E30 strut
  • ROLLingKING
    • Apr 2011
    • 1169
    I need a place to relocate my front sway bar. im looking for the brackets to weld onto my E30 strut tube and plan on using E30 sway bar links, the longer ones.
    But I cant find the tabs for sale to weld to the strut housings.
    Any help would be muuucho appreciated.
    m20 is plenty. im simply a drifter.
    build thread -- http://www.r3vlimited.com/board/showthread.php?t=206510
  • fronton
    • Oct 2009
    • 1262
    The tabs are part of the m3 struts, not individual part numbers, and I don't think anyone sells them aftermarket to weld on. If you are already welding them on, just fabricate some and weld them on.
    Can't you get adjustable links and keep them in the stock mounting spot?
    • bmwguy325is
      • May 2011
      • 1263
      http://www.akgmotorsport.com/catalog...0Reinforcement
      Very hard to find. If you run coils you can buy thread on style ones.
      And yes you can run adjustable links that mount to the control arm. This honestly is a better set up in my opinion.
      sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
      The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
      • nrubenstein
        • 3148
        It's only better if you don't need a stiffer bar. And honestly, given the way that the stock links get twisted around, I like the strut attachment a lot better.
        2002 BMW M3 Alpinweiß/Black
        1999 323i GTS2 Alpinweiß
        1995 M3 Dakargelb/Black
        - S50B32/S6S420G/3.91
        1990 325is Brilliantrot/Tan
        1989 M3 Alpinweiß/Black
        • mkcman17
          • Jul 2010
          • 8240
          i had castro's fab some tabs up and weld them on. the AKG ones are good pieces though.
          1989 LN106 Hilux / 3.0TD SFA
          1974 2002tii / stock
          2002 IS300 / 5spd LSD
          • E30_fiend
            • Apr 2006
            • 7348
            You honestly don't even need the adjustable links. Get some stock e30m3 sway bar end links and then fab a bracket to weld to the strut. Enough people on here have done it so you can get some measurements from on here.
            The reason I say you don't need the adjustable ones is because, more times than less, people set their away bars and forget it. Even a stock 20mm bar will react like a thicker bar with the change of geometry by adding the new link and tab. I heard that the difference feels like a 2mm thicker bar.
            Taylor
            • ROLLingKING
              • Apr 2011
              • 1169
              i have to relocate the sway bar links because i have e46 controlarms. i have the tabs and e30m3 sway bar links but not the exact measurement of where to weld it. akg sells the tabs to be welded onto the strut housing and they also sell the control arm bushings. good stuff.
              im going to look up some more information on the location and have it welded saturday.thanks for all the input
              • Acehye559
                • 1033
                Heres another one.
                • ROLLingKING
                  • Apr 2011
                  • 1169
                  yea i got the tabs..just looking up where to weld it exactly. since ill be lower than stock is there a better position for the sway bar to be loaded at?
                  • drumad
                    • Aug 2009
                    • 1700
                    measure yourself
                    disconnect sway bar from old links (both sides)
                    attach m3 link to sway bar
                    rotate sway bar until parallel with ground
                    mark the strut where the mount would go on the other end of the m3 link
                    This has to be done while there's a load on the wheels/front susp. If you put the front on ramps, the sway would end up being parallel with the bottom of the car. Hope that makes sense.
                    2008 335i - n54b30
                    1991 318i - m52b28
                    1994 fzj80 - LAND CRUSHER
                    • Jaxx_
                      • Dec 2009
                      • 1880
                      Originally posted by drumad
                      measure yourself
                      *perpendicular to the strut.
                      • drumad
                        • Aug 2009
                        • 1700
                        ya makes sense
                        2008 335i - n54b30
                        1991 318i - m52b28
                        • ROLLingKING
                          • Apr 2011
                          • 1169
                          measure yourself
                          great explination..ill put it up on the alignment rack and figure out where that puts me. hopefully tomorrow. thanks guys
                          • drumad
                            • Aug 2009
                            • 1700
                            make sure you note what Jaxx said
                            2008 335i - n54b30
                            1991 318i - m52b28
                            • ROLLingKING
                              • Apr 2011
                              • 1169
                              gotcha. i wasnt sure what it meant at first but im guessing he means dont follow the slant of the strut tube and put it perpendicular to the sway..
