Camber Correction= Waste of $$$?
RIP: Delphin '89 E30 with S50 swap and lots of goodies :'(
Then: '04 Evo 8 RS, 500 whp/420 wtq 2900 lb E85 AWD turbo shits 'n giggles
Now: 2003 BMW M5 in Sterling Gray -
Sorry guys, I was talking about the width of the wheel, which most definitely does affect the scrub radius and thus tire wear, especially dynamically. OP hasn't mentioned what kind of wheel setup he's gonna run, but it's moot because he's already picked the right parts for his suspension overhaul :up:--WillComment
a fuckload. just do most of it yourself, it's mad easy. springs/struts/mounts in an afternoonHey thanks for the help guys, really appreciate it. Here's what I've purchased.
4 x H&R Sport springs
4 x Bilstein Sport Struts/shocks
1 x TMS strut/shock mount kit (incl- Front upper strut mounts (guide support), standard alignment settings (not offset), Front and rear self-locking mounting nuts, Rear Lifetime Warranty 'Repair Shop' shock mounts, Rear shock mount gaskets)
2 x M3 offset control arm bushings
1 x Set of Urethane RTABs
1 x urethane steering knuckle
Any ballpark guesses for how much the installation will cost me at an independent shop?Comment
I went with oem rear subframe bushing and oem RTABs.
I guess I will get some urethane RTABs but stick with the OE sub bushings.Comment
Sorry to sidetrack but the treadwear rating and the driver affect how fast the tire wears an aggressive driver with low treadwear rating will eat through tires every single year on the axle that drives the wheels the most. In the case of my brother's corolla he chewed up his tires in under a year with oe lowering springs and nothing elseComment
