Clearance issues
  • SinisterE30
    • May 2012
    • 46
    Clearance issues
    So I bought the car alreadg lowered and with these wheels and tires. Is there anyway to gain mpre clearance in the front of the wheel? It has 215/45R17 was thinking about down sizing to 205's maybe? they are just rubbing on the front.
  • E30_fiend
    • Apr 2006
    • 7348
    Does the car have camber/caster plates? It looks to me like the camber is dialed WAY positive and they may have also installed M3 control arm bushings causing even more caster.
    Also, Is this clearance the same on both sides or just the one?
    Taylor
    • SinisterE30
      • May 2012
      • 46
      Its even on both sides. upon further inspection it looks like they just cut the front springs. No camber plates or anything like that.
      Do u mean the Caster is way positive? cause camber wise just by eye balling looks more neg then pos.
      • bmwguy325is
        • May 2011
        • 1263
        Yup put it back to stock LOL
        sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
        The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
          • 37833
          Tire is oversized. The correct size would be 215/40/17.
          Grover Beach, California
          BimmerHeads.com
          • AndrewBird
            The Mad Scientist
            • 11898
            Won't putting stock (taller) springs in make the problem even worse? With longer springs, the wheel would move down and forward in relation to the body. Something else is off here me thinks. Is the car 5-lug swapped?
            • SinisterE30
              • May 2012
              • 46
              No its a 4 lug still
              • DRTSRFR
                • May 2008
                • 1836
                Wrong e36 control arms maybe?
                Suspension tips here...
                http://www.r3vlimited.com/board/album.php?albumid=757
                • SinisterE30
                  • May 2012
                  • 46
                  Is there a noticeable difference in control arms? I can take a pic if that helps
                  • E30_fiend
                    • Apr 2006
                    • 7348
                    Lol, yeah. I guess thats what I get for not proof reading...
                    I'm on board with the E36 arm comment. That would give you more positive caster.
                    Taylor
                    • SinisterE30
                      • May 2012
                      • 46
                      okay. well how can i tell the difference between a e30 and a e36 control arm?
                      • CHIF8008
                        • 3447
                        give us pics of the front suspension components
                        -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
                        -The Beauty in the Tragedy-
                        MECHANIC SMASH!!- (you all know you do it)
                        Got Drop?? ;-)
                        But of course
                        E30s are know to be notoriously really really really ridiculously good looking
                        • SinisterE30
                          • May 2012
                          • 46
                          okay i will try and snap a few tomorrow when it is light out.
