IE3 for my first upgrade???
  • pyrobee
    • Jun 2012
    • 68
    I am thinking about ordering the IE3 springs for my first upgrade on my 318i euro spec. I am just doing some basic mods, and keeping it stock for now with those springs and my thule snowboard rack on top and tinting the windows, and then ordering some 15x7 rims later this summer. Is there anything I should watch out for. I want it pretty low and heard these were the way to go. Should I replace the rear tower mount braces or whatever too?
  • pyrobee
    • Jun 2012
    • 68
    oh and what is the biggest rim I could do with no mods with that suspension I just want to do 15's but have seen some 17's I like too. this is no race car just want a good tight ride, and something of my own.
    • Killacortes
      • 1937
      I would get bilstein shocks first. But that's just me
      r3v does not fuck around. First you get banned, then they shoot you
      • pyrobee
        • Jun 2012
        • 68
        get the shocks then the springs? I have almost new shocks. THat is why I was going to wait a little bit then do shocks and tires...but any suggestions are def appreciated.
        • Komzorz
          • Jun 2011
          • 332
          Springs and shocks should be done together so you don't waste time doing a similar operation twice, and also to have a matched set in terms of damping force and suspension travel.
          '87 325is - Schwarz/Schwarz
          • th3blue
            • 114
            these springs are a good starting point as long as you have good struts. I have them with bilstein sports and like them.
            1997 BMW 328ic 5spd sport Moreagrun Metallic
            1989 BMW 325is 5spd with a M50 swap
            2006 Audi A3 6spd DSG sport with APR stg 2
              • 37829
              I love IE3 springs. Don't install them until you've got some Bilsteins or Konis in there. Stock shocks will ride like shit and blow quickly. If you want your car low I recommend cutting 1/2 or full coil off the front since it's a 318. If you're referring to replacing the rear shock mounts, definitely a good idea while you have it apart.
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
              • pyrobee
                • Jun 2012
                • 68
                Can someone give me some links to the proper parts for the shock's/struts to put with these springs. I thought about cutting them but I would like the proper drop done.
                • CabbE30
                  • Aug 2009
                  • 2358
                  Let me help.
                  Get the IE3's with Bilstein Sports front and rear. Or you can get Koni's.
                  Get Rear shock tower mounts. I recommend Ireland Engineering or look on Bavauto.
                  While you're there, get e90 drop hats (~$30) for the front if you dont want to cut the springs or you can do camber plates (vorshlag/IE). Also, there's nothing wrong with cut springs if they are cut equally/ or if you want to resell them.
                  I have run 15's, 16's and 17's on this setup.
                  • CabbE30
                    • Aug 2009
                    • 2358
                    My last recommendation is to search, search, search & read, read, read on this forum. Everything you ever need to know about E30's is on here. You just have to take the time to find it.
                    • ak-
                      • 12422
                      What year is the car. I'd hate for you to buy 86+ shocks and not fit the early model housings.
                      1991 325iS turbo
                      • pyrobee
                        • Jun 2012
                        • 68
                        I am thinking about cuttin gthe stock springs for now. Just to get a little bit of a stance going. I am working on a small budget. Is there a write up on the proper way to cut these springs, and if I do, how will it affect the ride? I am actually going to run the stock tire and rim which is a 14 I am going for a stock look but a little meaner stance.
                        It is an 87 but a euro spec car.
                        • Blackout
                          • Apr 2011
                          • 4130
                          Ride quality will depend on how many loops you take out from the coil. The more the shittier.
                          » PARTS FOR SALE
                          » TRANSACTION FEEDBACK
                          • pyrobee
                            • Jun 2012
                            • 68
                            So how many coils do you all think would not kill the ride to much? Maybe bring it down an inch or inch and a half? How many cuts would that take?
                            • pyrobee
                              • Jun 2012
                              • 68
                              I just saw the post above that said a half to full coil? If I do a full coil I basically would cut them all right nderneath where the spring starts above it correct?
