Steering U-joint
  • PeaveyBassist
    • Sep 2004
    • 3511
    Steering U-joint
    So... in the past couple days I have noticed the steering feeling weird. It will turn normal and at a couple spots lock to lock it feels like it catches on something just barely, then lets go quick. It still feels safe to drive and I only notice it when sitting in a parking lot not moving and turning the wheel. I took off the steering wheel and the underdash bolster on the driver side to check out the column and see if it was obvious. Nothing was. I ended up shaking the column to see if it moved at all. With my hand on the column by the firewall, the column would move a little bit and make a quiet clunky noise. I jacked up the car and shook the column on the engine side of the firewall. The U-joint that connects the column to the steering rack has a lot of play in it. It should have almost zero play in it at all correct? My diagnosis is that I need a new lower U-joint.
    Will
    RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
    Welcome e30 (brilliantrot '90 325is) 12/23/06
    DaveCN = Old Man
    My signature picture was taken by ME! Not by anyone else!
    If people keep quoting me in their sig, I'm going to burn this motherfucker down.
  • nickmp0wer
    • 1427
    is your powersteering belt tight and is it full of fluid?
    • PeaveyBassist
      • Sep 2004
      • 3511
      Full of fluid. Pretty sure its tight but need to check. Regardless... shouldnt the U joint have almost zero play in it?
      Will
      DaveCN = Old Man
      • nickmp0wer
        • 1427
        yeah probably, but mine has play too, it makes the clunk noise when going over bumps and stuff
        • permit
          • Mar 2005
          • 3363
          AH HAH! You sir, are my hero. Now I know where that noise is coming from...thank god it wasn't suspension stuff.
          The u-joint from the stealership costs $170, I'm just going to take one from Devon's henna.
          • PeaveyBassist
            • Sep 2004
            • 3511
            lmfao I love you Jeremy
            Will
            DaveCN = Old Man
            • nickmp0wer
              • 1427
              well try and move your linkage around to see if it makes the clunk noise to be sure
              • Dave
                E30 RAT
                • 11675
                Any idea how hard of a job this is to replace?
                I have that same kind of clunking going on.
                Current Cars
                2014 M235i
                2009 R56 Cooper S
                1998 M3
                1997 M3
                • Jason89i
                  • Sep 2004
                  • 875
                  Originally posted by PeaveyBassist
                  It will turn normal and at a couple spots lock to lock it feels like it catches on something just barely, then lets go quick. ........My diagnosis is that I need a new lower U-joint.
                  Good diagnosis. I have had a few e30's (8 i think) and the first time this happened to me.....i almost went crazy trying to figure it out. if you let it get worse, the steering wheel will not return to 0 without assistance.
                  the u-joints go bad and get stiff.....but i havnt heard one make a clunking noise though.
                  the job is a pain in the keyster. first remove the rack. then remove the linkage. dont forget to fully remove the through bolt on the splined compression connector. some style ujoinst will not allow removal w/ bolt still in. i found it easiest to use an air chissle to get the splined connector off the rack and steering assembly.
                  cheers, jason
                  • Dave
                    E30 RAT
                    • 11675
                    Hmmmm. Ok, well maybe the clunk is something else. I'll pay close attention to see if I have the same symptom Will described. My suspension is all getting replaced soon anyway, so if the clunk is related to that - its no big deal.
                    Current Cars
                    2014 M235i
                    2009 R56 Cooper S
                    1998 M3
                    1997 M3
                    • wastedincome
                      • Aug 2004
                      • 906
                      I have a clunking in the column when going down my rocky drive-way, etc. I too have checked on it and believe it to be the U-Joints in the column...
                      Wastedincome420@yahoo.com
                      CURRENT STOCK LIST:
                      00' e38 750iL HighLine=Highway Queen
                      92' e30 318 vert=Aint going anywhere
                      91' e34 535iM=Aint going anywhere
                      91' e34 525iA=For parts
                      92' e34 535iA=For parts
                      • DEV0 E30
                        • Oct 2004
                        • 8904
                        Haha! I'm so charging you retail now!
                        Mine has begun to clunk a little too.
                        I think we found our next fuh raze product made out of kevlar and babies.
                        • nickmp0wer
                          • 1427
                          i think i have fianlly figured out the u-joint problem. It isnt in the actaul joints, its play between the shaft that goes through the guibo and the bushing around it. I'll post up some pics and info tmr
                          • madjurgen
                            • May 2005
                            • 1203
                            i have the same clunking and "sticking", replaced ps reservoir and flushed, nothing, thought replacing the steering rack was the only fix. this is good news, interested to see what you find.
                            As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
                            You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
                            • nickmp0wer
                              • 1427
