Advice on Strut Brace
  • jakker91
    • Jul 2010
    • 11
    anyone have any advice on a strut braces, are they worth it?
    Jack
  • ak-
    • 12422
    If your car has mildly stock suspension as far as rates and upgrades, yeah you'll feel a difference.
    If it's pretty modified and refreshed thoroughly, no not much difference.
    1991 325iS turbo
    • B-well
      • 1042
      exactly.
      and if youre trying to fine tune your track suspension they will eliminate any extra flex making spring rate calculations easier
      • Massimo
        • Jan 2008
        • 3207
        I would say yes. My shock tower is out of alignment, don't know why since it has never been in a crash. I can only assume from the sticky tires and harsh ride I have. But I think to keep your car strait and true they are worth it.
        • jakker91
          • Jul 2010
          • 11
          Awesome thanks for the info
          Jack
          • e30vert
            • Jan 2005
            • 1789
            Yes, Get one! I felt a noticeable difference once installed. Front of the vert felt more planted and suspension firmed up.
            Also, If you plan on running camber plates as many do consider the Sparco Strut Bar and not others as it allows the camber plates (Ground Control , Vorhslag , etc) to be installed as well as the strut bar. This is not the case with all strut bars.
              • 37832
              If you plan to buy one, check out the Ireland Engineering bar. They're local so you could pick up too.
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
              • marshtgrade
                • 161
                i have the I.E strut bar and love it. when i first bought it i put it on my vert with 4 blown shocks and damn did it make a difference keeping the front flat
