Odd *Cluck* front driver side
  • cardnation
    • May 2012
    • 123
    I've had this noise since day one, but its starting to irritate me. Its really only apparent over larger bumps in the road or dips that cause the wheel to drop and then rebound up. It sound is akin to something not bolted in or is coming unseated.
    I'm not really sure where to start with this problem.
    Any thoughts/ideas?
    BTW, Car is a 91 Cab with IE3 springs, shocks/struts unkown.
    Bad upper strut/shock mounts, mis-assembled front struts, bad sway bar bushings or links, bad CABS, or bad subframe bushings are things to look at.
    • DRTSRFR
      • May 2008
      • 1836
      ...also a loose strut insert.
      Suspension tips here...
      http://www.r3vlimited.com/board/album.php?albumid=757
      • Hellabad
        • 807
        I vote for broken sway bar bracket.
        Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
        Ground Control Gallery
        The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
        • cardnation
          • May 2012
          • 123
          Hm, I'll start checking all these things out. Thanks.
          BTW, What is "CABS"?
            CAB == Control Arm Bushing
