Camber plate install?
  • EDirtyZ
    • Jun 2012
    • 243
    Not sure if this is in the right place, but does anyone know of any write ups or installation to install GC front camber plates. I'm a noob when it comes to this so anything will help :) thank you!
    Installing camber plates is the same as installing plain upper strut bearings. You will have to remove the struts, compress the springs, and remove the strut nut to get the bearing off and replace it with the camber plate.
    • CabbE30
      • Aug 2009
      • 2358
      If you've replaced your suspension before then you already know how to do it. This time just switch the main strut bearing with the camber plate. Tada!
      • EDirtyZ
        • Jun 2012
        • 243
        CHEERS! Thanks :)
