Just woundering if anyone has heard of this brand coilovers. I was just surfing the web and come across this brand but have no info other than they make apps. for the e30 and other 3 series bmw.
Broadway static coilovers
They're great pieces. A friend of mine works for them. I was debating whether or not to get a set to replace my GC coils. I still don't know.
Anyway, they are dampening adjustable, and height adjustable. the camber plates they come with only adjust camber. No caster adjustment.
Hope that helps
TaylorComment
if you go to Stanceworks under the Suspension bit there is a really long thread but you can PM the guys there (Kielan and SeanDub from memory). You can also find them on facebook, they have a page.
They are more like quality of GC from what i understand, definately much better than BC. They will valve to match the springs and seem to take pride in assembling them all etc. I believe they use Fortune Auto for the coilovers and brand to Broadway Static as they get involved. The idea of them it to get very low so they offer basically the shortest possible bodies and shortest springs.
They are a weld on style in front like BC though not complete bolt in like GCComment
^ Sigh, they aren't true rear coilovers, they are separate spring and shock the same as pretty much all others. They just use short body dampers and the shortest springs that will work. From memory i think 5" all round?
the only company that readily sells true rear coilover for E30 is GAZ from the UK and they say just use upper shock mounts and off you go :P but the real issue is clearance behind the wheel with spring around shock on rear of e30Comment
Im looking into these coilovers too, Donno whats up with the name they are using on stanceworks "broadway Static" When these coilovers are the fortuneAuto coilovers from my understanding.
ahhh makes senseComment
