Removing top nut on strut
  • Beej '86 325es
    • 2639
    Am I missing something very fundamental here?
    The strut assy is removed and I've got a pipe wrench holding the strut shaft still, and a 19mm socket turning the nut at the top of the bearing. There's a LITTLE resistance, but it's just spinning. I'm wondering if it was tightened too tight and now the threads are stripped. Or am I just a dumbski missing something super easy?
    -Brandon
    '86 325es S50
    '12 VW GTI Autobahn DSG
    '03 540i M-Sport (sold)
    '08 Jeep SRT-8 (sold)
    For sale:
    S50 TMS chip for Schricks
  • royalflush313
    • Mar 2004
    • 2070
    not a solution, but I think you should have loosened the bolt before removing the assembly?
    ~ Go Canucks Go! ~
    • e30sd
      Fistee
      • Jan 2004
      • 5517
      use an impact, or throw an 8mm on the top nub of the shock shaft. that will keep the sucker from spinning.
      • Beej '86 325es
        • 2639
        I thought about that. I peeked through the socket while I turned it by hand, and the nub stays still, since it's part of the shaft. I'm thinking now that the nut is stripped or something. The plastic part of the locknut threaded it's way out. I think I might have to saw the shock apart just below the upper bearing.
        The other strut I didn't have any problem with at all.
        -Brandon
        '86 325es S50
        For sale:
        • Addissimo
          • Mar 2004
          • 1820
          Try decompressing the spring a bit, like all the way. See if all of that force will allow you to rethread the nut for a couple turns, then recompress the springs and have at it.
          Doing something M50 related? -> http://www.addissimo.com
          On Myspace? ->http://groups.myspace.com/r3vlimited
          BF2142 SN = BillyGoose
          • mrsleeve
            • Mar 2005
            • 16387
            inpact. or the saw method sounds like the best way
            Originally posted by Fusion
            William Pitt-
            • JPL
              • May 2005
              • 774
              yes, hack saw or if like fireworks use an dremmel tool powered by an air compressor. sparks everywhere.
              Originally posted by Hawt drift chick
              Yeah, i'm a good dude i swear, i just like to be balls to the wall.
              • Beej '86 325es
                • 2639
                I got the nut off...
                -Brandon
                '86 325es S50
                For sale:
