ggaahahahah!!! suspension noises!
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    I can't figure it out... I've been through all my suspension 3 times and still can't find the cause(s). Here's what's happening:
    From the rear, there is a loud and distinct "thwack" or "clack" when going over small, sharp bumps (like expansion joints). It's not a deep sound like a thud, but higher-pitched; like 2 small hard components smacking in to each other. I've checked every nut, bolt and cable in the rear end but can't find it.
    From the front, a distinct "squeak" when going over bumps on the left (drivers) side. Again I've checked everything under there and can't find a likely culprit.
    BTW I should mention I'm running GC Coils, Bilstien sport shocks, M3 CABs, stock sways w/ urethane bushings, Race Skids x-brace.
    Any ideas?
  • spike68
    • Apr 2009
    • 1185
    Maybe check your subframe bushings for the rear.
    As for the front, could i possibly get a little more detail?
    I don't even own this car anymore, but I'm too lazy to change the picture.
    • samiam3356
      • Jul 2009
      • 1901
      Did you raise the rear subframe 12mm? If so, then did you do the same for the Diff?
      Originally posted by Roysneon
      $5 shipped?
      Originally posted by MarkD
      You are a strange dude, I'n not answering any more posts from you.
      • E30_fiend
        • Apr 2006
        • 7348
        I would check the nipples on the trailing arm and chassis for marls of impact.
        What size spring are you running in the rear? Condition of rear shocks?
        As for the front, I would suspect that your poly bushings on the sways need some greasing. Use marine grease due to all the wet weather up in the PNW.
        Taylor
        • AndrewBird
          The Mad Scientist
          • 11898
          I was going to say the same. Use LOTS of grease. It's surprising how much bushing can squeak despite greasing them.
          Maybe the rear is a worn ring/pinion in the diff banging over bumps? Checking the endplay/backlash would tell you if that was an issue.
          • CorvallisBMW
            • 13039
            They're only a few years old, but I will check on them best as I can without dropping the whole thing out.
            Details on the front... It's hard to say exactly but it is absolutely a classic "squeak" noise. Not a "creak" or "groan" like I've heard before from urethane. My bushings are about 2 years old but I'll pull them off and grease them up just to be on the safe side.
            No, subframe is stock aside from eccentric TA adjusters
            Taylor
            Rear is GC, 6" I believe? I can't remember exactly. Rear shocks are in good shape, maybe 30K miles. The upper shock mounts are Bimmerworld with the "lifetime warranty"
            I might try pulling the DS and checking it out, maybe I'll find something hiding under the heat shield. I also want to pull the rear discs and look inside the e-brake assembly, make sure nothing is loose in there.
            • EyExR
              • Jan 2011
              • 959
              On the rear, get under the car and shake your muffler around. Is it hitting anything at all?
              Front - I'll repeat what others have said, check your sway bar bushings. How long has it been squeaking?
              I've also had the brake pad retainer spring squeak on me in the past...
              My 325iX DIY Threads:
              Front Wheel Bearing Replacement
              325iX Rear Subframe Bushings and MUCH more w/pics!
              325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
              • giantkeeper
                • Aug 2009
                • 1416
                Any update on the rear?
                I have had this issue since installing the GC's in my car. Not horrible at first, but since I downsized my tires I lowered the car more last weekend. Now it's worse and happening far more often.
                I'll get her up this weekend and see what I can find.
                Always Always go for the reach around if there is an option
                • CorvallisBMW
                  • 13039
                  Did the muffler check, nothing made any noise. The front has been squeaking for 2-3 months now, and I put the bushings in about 2 years ago. I lubed them up but it's still there :/
                  Rear still clicks and clacks, yet I can't find anything loose or out of place...
                  • Hellabad
                    • 807
                    Front:
                    Check for water internally in the Bilsteins. Seriously
                    Second idea: If you raise the car slightly, and the noise changes or goes away then the noise is from the internal bumpstop of the Bilstein.
                    Third idea: undo sway bar links (completely) and see if the noise goes away
                    Rear:
                    Loose rod end on sway bar link?
                    Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
                    Ground Control Gallery
                    The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
                    • CorvallisBMW
                      • 13039
                      ^all good ideas. I'll have to give them a try.
                      • giantkeeper
                        • Aug 2009
                        • 1416
                        I peeked under the car today when I got home and identified a rear exhaust hanger donut bought the farm.
                        Was not the issue.
