ST Lowering Springs
  • BamaE30
    • 239
    #301
    "Andrepuffin" like the E12 I have a few clogging the driveway
    Imported from Detroit
      • 37826
      #302
      Originally posted by GodIse30
      Wow, I got my springs in ONE day. They must be really close by to where I live.
      They're in Fresno.
      Classic BMW Specialists
      Santa Clarita, CA
      www.BimmerHeads.com
      • Swanny
        • Mar 2012
        • 2834
        #303
        Originally posted by 5Toes
        Hahaha mine came with an oldschool decal. WOOT
        Post that shit!
        Swanny!
        SUCKERS.
        • Swanny
          • Mar 2012
          • 2834
          #304
          Originally posted by Laura
          stock shocks (for now), cut bumpstops, e90 drophats:
          I'm so excited :)
          Do you mind get a clearence measurement of your oil pan for me? I have the same springs and was looking to do the drop hats as well. Already got a few new scraps on my pan.
          FU upstate ny roads!
          Swanny!
          SUCKERS.
          • HerbReal
            • Feb 2012
            • 767
            #305
            Here's my ride height on each sides of the car plus clearance from bottom of IS lip to ground. The oilpan to ground clearance is about 3" (couldn't take a picture because it's simply too low). Sorry for the poor quality images, Enjoy.
            IS Lip to Ground:
            Driver rear side fender:
            Passenger rear side fender
            Passenger front fender (The fender is smashed, needs to be replaced.)
            Driver Front fender
            Herb
            - 98 M3 Cabrio
            Photo work: http://www.herbreal.com
            Instagram: @herbreal
            Twitter:the_herb_real
            • Bimmerguy91
              • Jul 2012
              • 982
              #306
              I've got a good fender.
              • Laura
                • Jun 2011
                • 451
                #307
                Mine's pretty much the same as HerbReal's. my oil pan is about 3" off the ground, maybe 2 3/4" at the least.
                • alpineII_dirty
                  • Apr 2012
                  • 186
                  #308
                  Wow im surprised no reverse rake on the 318, with vogtlands i have a bit of reverse rake, probably consider getting a set of these springs
                  • ButtJuice
                    • Dec 2009
                    • 2609
                    #309
                    This is after less than 24 hrs of them being installed. They've settled since then and I put euroweaves on. I'm kind of lazy to take more pics atm, but I will later.
                    1991 318is - Sold
                    1986 325 - Sold
                    Instagram - Lamoursum
                    • Bimmerguy91
                      • Jul 2012
                      • 982
                      #310
                      ^post the new pics!!
                      • K1CKBAC
                        • 306
                        #311
                        Just ordered the M3 set. Read the thread and some people say its stiff like H&R race and some says its smooth. I have a feeling the M3 set is stiffer. Will report back once I install them.
                        My expectation is an immediate 5 speed swap. Autos suck more than a 50 year old whore.
                        • Andy.B
                          • Sep 2011
                          • 1650
                          #312
                          I ordered the ST m3 springs, which arrived today.
                          I am going to install them on my 87 325e coupe. My suspension setup is currently:
                          Front: KYB gr2 shock inserts, stock springs with one coil cut off, and e90 drop hats, and all spring pads in place.
                          Rear: KYB Gasadjust shocks, h&r sport springs, all spring pads in place.
                          I am debating whether or not to install the drop hats in the front, and whether to pull some or all of the spring pads.
                          I am relatively happy with the ride height, although I would like the rear to be a little lower. I bought the ST springs hoping they are stiffer then my current setup.
                          Has anybody installed the ST m3 springs in a 325 (non convertable) yet? I am curious to see just how low they are. Any advice on drop hats, spring pads?
                          (And yes, I know the KYB's are too weak for these springs. I will deal with that later.)
                          • Andy.B
                            • Sep 2011
                            • 1650
                            #313
                            Using this spring rate calculator, and the measurements from my ST m3 springs, I got:
                            Front spring rate = 128.5 in/lbs
                            Wire Diameter: .498 in
                            Spring OD: 5.622 in
                            # of active coils: 5
                            Rear spring rate = 316.3 in/lbs
                            Wire Diameter: .592 in
                            Spring OD: 5.615 in
                            # of active coils: 4
                            Which puts them relatively close to the stock m3 springs (depending on the source).
                            I am unsure of just how much I trust this, but it is very easy to do, and seems very believable, given their application, and the drop the promise.
                            If anybody has a set of the 318 springs handy, and could calculate them for comparison's sake, I am sure others would be interested to know.
                            • einstein57
                              • Jun 2007
                              • 10780
                              #314
                              There are 5 uncompressed springs up front under full load? Also springs are almost never an exact # of coils. It can be something like 5.2 coils. etc
                              www.gecoils.com
                              • ButtJuice
                                • Dec 2009
                                • 2609
                                #315
                                *1991 318is springs on a 325i
                                IMO, they kick ass. Not too low nor too high, I'm satisfied. $70+tax at it's finest.
                                (the angle might show more wheel gap than it appears in person)
                                1991 318is - Sold
                                1986 325 - Sold
