Hi,
I haven't done this before and would need some help with it. The fluid in the reservoir is leaking from the underside, and I checked that its the return hose is a bit old. I have the part with me and ready to replace it along with the fluid as its dark brown. But before I proceed I would like to know that if I change the fluid, is there anything else that I should watch out for?
1. Can I drain the whole steering rack of its fluid? If yes, do I need new oil seals for that?
2. How many liters would I need? So far, I only bought 3 liters.
3. What's the best way to clean the rack of its dirt? I'm not sure whether pure gravity and laying it on its side is the best way, or can I tilt the car to one side, and let compress air push out the oil from the rack.
Would appreciate technical advice. Thanks!
