What are the best camber plates?
  • =======Live Fast!
    • Nov 2011
    • 248
    Just curious what people are running. My brother is about to invest in a set and wanted to know what the masses thought as there are several companies manufacturing them at a wide range of prices.
    sigpic2000 323ci
    1987 325is super etta
    1988 M5
    2000 M5
    1989 944 turbo
    1989 325is
  • e30_325es
    • 1249
    vorschlag
    • SkiFree
      • Jun 2011
      • 2766
      I'm sorry but nobody makes "the best" camber plates. I know more than a few people who couldn't wait to get rid of the vorshlags (certainly know a few who swear by them as well).
      There are several good plates out there as you mentioned, none of them are going to be BAD if you stick with the recognizable names (GC, Vorshlag, IE, etc.). It's pretty hard for a decent manufacturer to screw up camber plates.
      FIRST we could use a bit more info on your end.
      what kind of car is it (street performance, low-and-stupid, dedicated track car)?
      what is your brother expecting out of them (Fix camber? Be super stiff)?
      ADAMS Autosport
      • hooken m
        • 1537
        i use IE street/race. im pretty please with them.
        Originally posted by evandael
        a car is a car. call it a dildo, i'd still drive the hell out of it.
        • bmwguy325is
          • May 2011
          • 1263
          I paid a race shop to build my coilovers and they chose the vorshlag plates.
          I have liked them.
          sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
          The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
            • 37833
            People need to realize that race plates on the street are a bad idea. Tons of added noise and premature wear is immanent.
            I run the GC Touring plates and they are excellent!
            Grover Beach, California
            BimmerHeads.com
            • e30trooper
              • 11576
              how can i tell if my IE plates are race or street?
              currently pushed to the engineside. PO said IE race..
              • e30trooper
                • 11576
                after looking at pix. they do look like the race's off IE page
                this is street plates
                and spec e30
                • VinniE30
                  • 2113
                  What make the street plates better for the street?
                  And what makes the race plates better for race?
                  Zinno '89 <24v swap in progress>
                  • bmwm42
                    • 6300
                    Gc hybrid plates
                    Originally posted by bmwm42
                    PNW vulture pm me for parts
                    Strategic nw e30 command
                    • SkiFree
                      • Jun 2011
                      • 2766
                      I REALLY don't want to make this an info-mercial so I'll abbreviate this.
                      Basics on the IE plates
                      Street: Simple, uses stock rubber upper strut mount. But adds to suspension stack-height, and doesn't offer as much adjustment. Frankly I'd just run fixed plates instead of these.
                      Street/Track: Replaces stock USM with a replaceable spherical bearing encased in urethane (for dampening road vibrations). can use stock diameter 5" springs or 2.5" c/o springs.
                      Race: Replaces stock USM with a replaceable spherical bearing (NO dampening for road use). Vibration is transmitted directly through the bearing. Should be considered a wear item like all other heim-joints, bushings, etc. accepts 2.5" c/o springs only.
                      Again, it's hard to go wrong if you simply call someone like GC or IE and tell them what you're looking for. I personally agree with Matt though, race plates tend to not be ideal for street driving.
                      ADAMS Autosport
                      • giantkeeper
                        • Aug 2009
                        • 1416
                        Same here and I agree
                        Always Always go for the reach around if there is an option
                        • Ludey849
                          • May 2011
                          • 58
                          anyone know what camber plates work with fk coilovers?
                          • nrubenstein
                            • 3148
                            By a wide, wide, wide margin, the GC Touring plates are the best for normal street use. I haven't seen anything that gets even in the same ballpark. The only knock is that they are not as adjustable and are a bit taller than a proper race plate. If you want to touch your oil pan to the ground, these aren't the best choice.
                            Normal street plates use a stock strut bearing and are best described as utter crap - they are taller than the stock top hats and just terrible.
                            "Race" plates use spherical bearings. This means noise, vibration, harshness and rapid wear. There are many varieties of race plates and they generally have their own virtues. GC, Vorshlag and TC Kline have the best designs, IMHO. GC wins on absolute adjustability (and IIRC on stack height). Vorshlag has an elegant design. TC Kline makes a nice plate.
                            2002 BMW M3 Alpinweiß/Black
                            1999 323i GTS2 Alpinweiß
                            1995 M3 Dakargelb/Black
                            - S50B32/S6S420G/3.91
                            1990 325is Brilliantrot/Tan
                            1989 M3 Alpinweiß/Black
                              • 37833
                              They are 12mm less stack height than a stock strut mount though.
                              BimmerHeads.com
