Spring pad removal Rear. Need quick help!
  • m3/e30fanatic
    • May 2011
    • 2969
    removing my rear pads. cant i just cut them and itll come out? and is this safe? what will my spring sit on?
    thanks.
  • m3/e30fanatic
    • May 2011
    • 2969
    bump please
    • Swanny
      • Mar 2012
      • 2834
      Spring pads?
      Swanny!
      SUCKERS.
      • Swanny
        • Mar 2012
        • 2834
        It sits on the metal surfaces the pads are on. F34r helped me get mine out and its simple as pop the spring out, pull the pad off, sand off any corrosion, hit it with some rust inhibitor, install springs then enjoy. Totally worth losing them and next to no added noise.
        Swanny!
        SUCKERS.
        • m3/e30fanatic
          • May 2011
          • 2969
          so i need to take out the spring? i cant do it with it on there?
          • Swanny
            • Mar 2012
            • 2834
            Correct
            Swanny!
            SUCKERS.
            • m3/e30fanatic
              • May 2011
              • 2969
              how do you take out the spring? is it a tool i neeD?
              • Swanny
                • Mar 2012
                • 2834
                Jack up the rear. Disconnect the strut. You can take off the sway link and that should let the rear trailing arm drop enough to just pull the spring out. Since it sounds like you're new to this i'd say play it safe and rent some spring compressors from autozone/oreily's/advanced auto. I had help from f34r so he's a great source if you want some pointers.
                Swanny!
                SUCKERS.
                • Tree18is
                  • Mar 2004
                  • 2703
                  Holy fuck
                  Guess its a little harder that the blue spray paint huh? I'm glad they closed autoshop.
                  • Tree18is
                    • Mar 2004
                    • 2703
                    Customs says any metal to metal contact will start a fire! Be carefull lil guy!
                    • m3/e30fanatic
                      • May 2011
                      • 2969
                      haha, haters gon hate man.
                      I've asked your car if it was fs at 7-11 on la crscenta i believe.
                      • ak-
                        • 12422
                        lmao
                        1991 325iS turbo
                        • m3/e30fanatic
                          • May 2011
                          • 2969
                          is this bullshit :hitler:
                          • Mr. Tasty
                            • Jul 2011
                            • 3421
                            my fronts make more noise without pads than the rears.
                            2014 Alpine White 335i MSport
                            (Daily Driver)
                            Full Mperformance Aero
                            KW V2 Coilovers
                            VRSF Catless Downpipes
