I don't understand this, I installed the upper spring plates and there is no difference. In fact it looks to be a little bit higher on the one side I did install one on. Any ideas why this may have happened?
E90 upper spring plates installed - no drop
Did you drive/roll the car after the install?
Also, if you only did one side you will not notice as much drop. -
I think he may have only done one side...Comment
Yea I drove the car around after - it's been a day or so.
Did that :\
I've only done one side - that is correct, but I still should have noticed a slump on that one side correct?
YesComment
That is why...Comment
2 great threads in a row!!Comment
dude you got to do both sides when i lowered my e30 i finished one side and was so stoked to drop it off the jack to see how low it was and it wasn't lowered at all really then i did the other side and i couldn't even get the jack out from under the car couse it was that much more lowered and after i set the wheels drove it took some turns got home and it was even lower. haha patience my friendComment
