Ground Control
  • isthistherealcaesarspalace
    • Mar 2012
    • 140
    Ground Control
    I was in the process of changing my old set up to this.
    my question is how the front adjustable springs sit because it does not clear the collar of where the shock slides into and the spring is much smaller then oem.
    please help im at a standstill since ground control is closed sat/sun.
  • E30_fiend
    • Apr 2006
    • 7348
    You have to take off the strut insert hold down nut then slide the adjuster sleeve over the strut tube then re install the hold down nut. If you didn't know already, you need to cut off the stock spring perch and weld on the supplied collar from GC.
    Taylor
    • e30leigh
      • Mar 2012
      • 481
      alot of people ask this very same question. its not hard to figure out.
      • DRTSRFR
        • May 2008
        • 1836
        Did you get it sorted out?
        Suspension tips here...
        http://www.r3vlimited.com/board/album.php?albumid=757
          • Mar 2012
          • 140
          kinda...Adam over at ground control told me for my car 91' 318is I don't have to cut to perches unless I want the car so sit lower.
          • DRTSRFR
            • May 2008
            • 1836
            If you need more help, call and ask for me personally.
            I have some pics I can send you which will help.
            Mark
