What's wrong with these Bilstein's?
  • E30stan
    • 658
    When I compress these rear struts, one of the struts compresses about 2 inches further than the other. The pressure required to compress and the rate at which they decompress seems identical, what could account for the difference?
  • E30_fiend
    • Apr 2006
    • 7348
    Same part numbers?
    If they are, remove the black dust covers and see if one has an external bumpstop installed.
    That's my guess.
    Taylor
    • kronus
      • Apr 2008
      • 13032
      The internal bumpstop may have disintegrated in one of the two, in which case it's probably on the way out in the other one, as well.
      Alternatively, you have a Bilstein Sport and a Bilstein HD. Check the part numbers.
      cars beep boop
      • E30stan
        • 658
        Originally posted by E30_fiend
        Same part numbers?
        That's my guess.
        Taylor
        Part numbers are identical, i already disassembled both units and they both have the chicken patty bump stop, and both looked fine. On a side note, one of the rear sway bar mounts had broke off, so im thinking the uneven geometry could have had an effect on the struts. I wonder if these struts are ok to drive on?
        • e30leigh
          • Mar 2012
          • 481
          nope. send them in and have them rebuilt with new seals and internal bump stops. your car will be handling like crap with those in atm.
          • E30_fiend
            • Apr 2006
            • 7348
            What he said. Unfortunately they have internal bumpstops so you can't take them apart up check them.
            Taylor
