Early Model Rear Race Spring selection
  • Mr. Tasty
    • Jul 2011
    • 3421
    I am trying to decide whether to go 6inch 800# or 4 inch 800#. As of right now I have 40mm lowering in the rear, and I want there to be pretty much no finger gap between the fender and tire. Tires are 205,45,16. What would your guys' oppinnions be?
    2014 Alpine White 335i MSport
    (Daily Driver)
    Full Mperformance Aero
    KW V2 Coilovers
    VRSF Catless Downpipes
  • Mr. Tasty
    • Jul 2011
    • 3421
    my rear adjusters measure in at 0.75 of an inch, should I just go with a 4 inch spring and adjust up to my taste? or go with 6inch and pretty much have the adjuster as a "centerer"
    (Daily Driver)
    KW V2 Coilovers
    • acolella76
      • 2950
      I have a 742lb 5.5" spring in the rear on an adjuster that's turned all the way down and there is about a 1 finger gap between the wheel and fender. Use a 5" spring..
      -Alex
      • Mr. Tasty
        • Jul 2011
        • 3421
        I can't find anywhere that makes a 2.5 5inch spring. Both hypercoil and eibach only make 4 or 6.
        (Daily Driver)
        KW V2 Coilovers
        • Nick's e30
          • Mar 2012
          • 676
          Go with the 4'', im running a 205-40-16 with a 9'' wide 15mm offset wheel and tuck tire, but when I spin them up I can go up to over 3 fingers of gap..
          No antenna? I sell plugs!
          Here: https://www.r3vlimited.com/board/sho...77#post4937877
          • Mr. Tasty
            • Jul 2011
            • 3421
            that's what I figured, thanks.
            (Daily Driver)
            KW V2 Coilovers
            • E30SPDFRK
              • 5707
              Are you sure the rear springs should be 2.5" ID? All GC kits I've had and worked on take 2.25" ID rear springs. Your adjusters may be different though.
              Either way, I'd say get the 4" spring. That stiff of a spring will barely compress anyways, so you'll have plenty of adjustment both up and down. All the way up should give you about 1.25" of gap between the top of the tire and the fender. A 6" 800lb spring would be the same height as that when adjusted all the way down.
              And for future reference, Swift makes a 65mm ID 5" spring that is pretty much the same as 2.5"
              Byron
              Leichtbau
              • Mr. Tasty
                • Jul 2011
                • 3421
                yes they are 2.5 ID adjusters, I found some cheap 4inch springs, and tested them. It will be perfect for what I want. I ordered them last night.
                (Daily Driver)
                KW V2 Coilovers
                • Mr. Tasty
                  • Jul 2011
                  • 3421
                  they aren't GC adjusters.
                  (Daily Driver)
                  KW V2 Coilovers
                  • Jalves619
                    • 596
                    Who makes those adjusters? I'm dealing with the same thing now. The 6in spring in the rear is too high even without an adjuster so I'm probably going to drop to 4 inches and put adjusters in.
                    • Mr. Tasty
                      • Jul 2011
                      • 3421
                      not sure of brand, buddy of mine gave them to me for 50$. I was able to tuck .25 of 205x45x16 tire in the rear with 4 inch and adjuster on any early. It is going to be perfect when I adjust up.
                      (Daily Driver)
                      KW V2 Coilovers
                      • Mr. Tasty
                        • Jul 2011
                        • 3421
                        primarily I went with 4inch springs because of my early model.
                        (Daily Driver)
                        KW V2 Coilovers
