GE Coilovers and strut insert rates.
  • wakdog
    • 223
    Im probably going to pick up a pair of GC koni front inserts, then get these billy HDs revalved and a mate can use them in his car....
    90 318i M62B44 OBD1
    02 530i Touring (Airlift 3P)
    • graphikg
      • Jan 2008
      • 1614
      Ya - these billies are not cutting it for me. Too bouncy and my front passenger shock is already blown completely. I think I also have to swallow it and do konis or even go with the mr2 inserts. I'm just concerned if some new front inserts will apply to the GE camber plates. I DEFINITELY need something stronger though.
      • wakdog
        • 223
        Yeah ill need to see what to do about the IE camber plates i got from nigel, dunno if they will be a direct fit if i get koni inserts...
        90 318i M62B44 OBD1
        • graphikg
          • Jan 2008
          • 1614
          Update - the shock was definitely done for it. I decided to just send the front set back to Bilstein and have an order form filled out to be revalved stronger for my suspension setup. I will just make sure they revalve them to handle the extra weight in the front from the swap plus the 450lb springs.
          • noE30
            • Jun 2008
            • 2260
            Im running the same setup up front on my car, and I wouldn't describe mine as bumpy at all. And thats lowered down about 2/3rds of the threads, ~22.5" fender to ground on 205/45/16s. Maybe you had a bad batch of shocks?? Let us know how the new setup works out.
            Flickr
            @michael.colby on Instagram
            "All he needed was a wheel in his hand and four on the road"
            • graphikg
              • Jan 2008
              • 1614
              Anywho... iX Bilstein valving is not suitable for 450lb springs I dont think. Bilstein wouldnt disagree either. But that could be because they want to make more $$$. Who knows. There is a chance I had a bad shock...
