Ps res leaks bad and i want to replace the hose coming from the res and clamp. Advice on performing this? I figure ill disconnect lower and drain res, replace hose, refill res with fluid. Now my question is whether i need to be concerned with bleeding the system or anything like that?
Power steering hose replacement question
Fill the P/S fluid back, turn the steering wheel lock to lock a few times. Add more fluid if needed. Turn the steering wheel again and add more fluid if needed... make sure car is running of course. Drive it around a little with few turns and check your fluid level. Add more fluid if needed, if not, you are done
