So I installed the BC Racing coilovers the other night and when I am driving, I hear this clunking noise coming from the rear passenger side, so I double checked the shock mounts and made sure the two nuts were on there tight. I torqued down the bolt connecting the shock to spec as well. It kinda seems like the spring is somehow moving around so last night I put the car on the lift and double checked to make sure everyone was installed properly and it was. I am not sure if this is the same with other companies but for maximum drop you remove the adjusting collars on the spring, which I did and you adjust the preload from the shock I think.
Anyone else with BC Coilovers have this issue? My friend has the same setup with the same spring rates (10K front 12K rear) and he only installed the rears so far and he gets the same clunking noise from the driver rear side. Same sound. Any suggestions would be appreciated. Today I am going to check to see if the center nut underneath the adjusting knob from the shock mount is loose and double check the locking collar on the shock.
