adding height to H&R race?
  • Daeldalus
    • Nov 2012
    • 304
    I plan to make my car a DD and an AutoX car and i like a stiff ride anyway
    so just about the only way for me to go is with H&R race springs(coilovers
    not allowed in my class) but a 1.6 inch drop may be a bit too low for the
    roads i drive on a daily basis, I don't know for sure but i do not want to
    destroy an oil pan or puncture my gas tank.
    so the question is, is there any thing i can make to give me say another 1/2
    inch of height? i was thinking i could make a rubber spacer to go under the
    rear spring pad but i don't know if that would work and i don't have a good
    idea of what to do for the fronts...... so is there anything that can get me
    what i am looking for here?
  • priapism
    • 1182
    That kind of eliminates the point of those H&R Race springs...why not just go with the Sports, which already sit higher?
    -Sean : 91 Calypso 325i : Castro Motorsports SoCal Spec E30 #33
    • brent5631
      • Jun 2012
      • 421
      Because of spring rates. Adding a spacer should be no issue and get you what you want. Maybe on the cheap you can double up in the rubber idolaters that are already there.
      • priapism
        • 1182
        Yeah but it raises the CoG up. I guess it's doable...
        • Daeldalus
          • Nov 2012
          • 304
          should i just fab up some custom skid plates to cover the oil pan and other vital bits and just not worry about the height?
          does the H&R race springs have any tire clearance issues under hard driving?
            • 37832
            There are OEM spring pads that are a lot thicker, you could install those.
            Part number is 31331128522 for the front. If you use this one on top and bottom you will gain 12mm of height.
            Part number is 33531136387 for the rear. This is only designed for the bottom in the rear but you can probably use it top and bottom. Using it top and bottom will give you a total of 10mm additional height.
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
            • Daeldalus
              • Nov 2012
              • 304
              yes... that is the kind of answer i was looking for.
              as long as they are not stupidly expensive i think ill try that.
              • bmwguy325is
                • May 2011
                • 1263
                not allowed in my class)........
                What class will not allow coil overs?
                sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
                The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
                • mulletman
                  • May 2012
                  • 801
                  Last I checked, bimmerworld also sold spring pads in a variety of thicknesses.
                  • Sagaris
                    • Sep 2009
                    • 2243
                    Typical MacPherson stut suspension on a passenger car will have the roll center decrease faster than the cg decreases when lowering ride height, which increases roll couple and thus body roll. Of course the cg and roll couple would need to be determined to say what amount of lowering/lifting yields the best result BUT the moral of the story is, lowering the cg is good, but on many cars the roll couple increases quickly and assuming the spring rates are the same, you can end up with less body by increasing the ride height.
                    • Daeldalus
                      • Nov 2012
                      • 304
                      I plan on running in STX which will allow coilovers on the front since the
                      original suspension in the front is the same spring setup as a coilover.
                      but in the rear i cannot switch to a coilover because the original location
                      of the rear spring is not over the rear shock.
                      so instead of trying to find just front coilovers i figured i would just do the
                      whole car on H&R race springs.
                      • bmwguy325is
                        • May 2011
                        • 1263
                        Wow ok.
                        So HR threaded spring perches in the rear wont work? Then you can adjust your ride height all sorts of ways.
                        • Nsquared97
                          • 1656
                          I've got great news for you, most E30 coilover setups are perfectly legal in STX. Reason being that most 'coilover' setups for the rear of our car keep the spring in its original location (not technically a 'coil-over-damper' setup like you would think when you hear coilover). Check out GC's coils, or even look at IE's rear kit:
                          • misterCAFE
                            • Oct 2012
                            • 57
                            ^^ this guy is correct about most coils not being "true coilovers" as most do not surround the rear shock. go gc and be done
