Alright folks, I'm hoping to get some input as to what I'm trying to plan. Let me know what you think of what I've got planned out, any positives/negatives, or anything you'd change. I've done a fair bit of searching and reading... But I'm just looking for a few knowledgeable opinions before I start ordering stuff.
My goal is to essentially completely rebuild the suspension on my 325is. I want it to be low enough to look decent, but simplicity and performance are my main goals. I'll sacrifice a little aesthetics in a heartbeat for proper performance. Height adjustability is not needed, nor is it desired.
The chances this car will ever see an actual race track are almost zero. I have a motorcycle for that. However, some autocross events would be fun. I don't have to daily drive this thing either, but I'd like it to be comfortable enough for a drive through the mountains without feeling beat to death when I get there. I have a fairly high tolerance for harshness, though. Usability is important... I'd rather not be hitting bump-stops all the time.
Plan thus far:
-Full bushing replacement. Likely parts from Condor Speed Shop. Offset subframe bushings, TAB's, diff mount, M3 CAB's. Did I miss any?
-Control arms (if necessary)
-Bilstein sports (cut bump stops to retain some shock travel)
-H&R Race springs
-Rear shock mounts. Which ones? I know GC makes some that are taller to preserve shock travel. Worth it?
-Camber plates? Are these necessary? I know the stack height is less than stock, thus yielding a little more shock travel. A bit of alignment adjustment would be nice, but not entirely necessary. How is the front shock travel with the setup I've described?
-A set of sways, with reinforcements welded where necessary. The UUC kit and Bimmerworld kit both look nice. I'm not planning on mounting the front sway on the strut, but in the factory location.
So that's the general idea thus far. Any thoughts? Overkill? My goal is to do it right the first time... Thanks for the input.
-Ben
Plan thus far:
-H&R Race springs
-Ben
