Need to make some more room for headers as im changing to 1 7/8" primaries on the LS1. Vorshlag make a kit to remove the original linkage and replace it with a much thinner and compact linkage, but as much as I think their product is a great bit of kit, I can't justify the $385 cost when It looks like you can get the same components for about half the price.
Seems like a total no brainer to just go ahead and order the same unis from flaming river http://www.flamingriver.com/index.ph...ts/c0005/s0008 which run to about $80 each
And buy the Double D steering shaft in the correct length from pretty much anyone (summit, jegs, etc) which will run to about $20-$40 depending on length.
$200 vs $385, see what I mean?
Question I have though is, anyone know what spline count the E36/Z3 rack is? I know the E30 item to the steering shaft/column that seems to be used is the 17mm, 54 spline uni which is #FR1963, but what about the other end for the E36/Z3 rack? is it just the same spline count?
Just fyi, im ordering some more parts for my LSX build from summit and the FR1963 uni is $70 and some 3/4" Double D shaft is $14.
