I need to remove the airbag steering wheel on my 1990 E30 so as to check the wiper switch. What I don't want to have happen is detonate the airbag, so I thought I'd see whether I could get some guidance here before I went any further. The Bentley manual has nothing on the topic.
I already have disconnected the battery. There is a small pry-off panel on the underside of the steering column behind which is a connector, which I'm guessing is the plug for the airbag detonator. I expect I should unplug this. There are several screws in the steering wheel on the side facing forward/away from the driver that I'm guessing hold on the airbag cover. These in particular I am reluctant to remove before getting some guidance.
Any thoughts on how to get this thing off, and things I ought to be looking out for? Many thanks in advance.
